Bigger Injectors for WET NOS?
I'm making 525 RWHP and am currently running 40lb GM injectors that came with the L76 manifold. I'm getting ready to install a 125HP ZEX Wet Nitrous system. Do you think it's necessary to move up to 60lb injectors too? How would larger injectors affect daily driving?
You dont have to upgrade injectors on a wet kit. Dry is where the injector upgrades come in. Just make sure your fuel pump can support your needs and you are good to go fuel wise.
+1 on that
I have the Racetronix 255L pump with harness and I just added a Kenne Bell Boost A Pump. I am very close to you HP wise and I am only going 150 shot on my wet plate system.....if the BAP doesn't do the trick a Twin setup will be on order.
