Fuel Injectors
Old Aug 26, 2008 | 10:01 PM
Bad Chad's Avatar
Default Fuel Injectors
What is the difference between low impedance and High impedance...
I'm still new at fuel injection and turbos so I want to be sure to get the right parts
Old Aug 27, 2008 | 11:04 AM
Bad Chad's Avatar
For a 2001 Corvette with twin 40's do I need high or low impedance injectors?
Old Aug 27, 2008 | 12:46 PM
ZL1Killa's Avatar
you want high impedance. what power level are you looking at i can spec you out or NastyN8 up here can spec you out a killer fuel and injector setup
Old Aug 27, 2008 | 01:51 PM
Bad Chad's Avatar
I don't think I will make more than 500 to the wheels. The motor is 100% stock and I plan on using 60# injectors and upgrading the fuel pump...
When this build is done i'm going to start building a 6.0 short block to replace the stock block. I don't want it too radicial since I daily drive the car, I just wanted more power. I chose the turbos because they are quiet vs a heads, cam and exhaust car.
Old Aug 27, 2008 | 02:27 PM
1INSANEGTO's Avatar
I have some 60Lb injectors I will let go for $375.00 They only have dyno time. Plus they will work for your app. I can not use them I have to get bigger injector and a driver box.
These are Mototrons (spch)
Old Aug 31, 2008 | 01:46 AM
2000WS6ICK's Avatar
High will work with your stock PCM, Low are for aftermarket PCM's.
Old Sep 2, 2008 | 07:47 AM
ZL1Killa's Avatar
if you are wanting no more than 500HP~ give or take a tad, some 42# or 50# would be your max you would want
