LS7 Fuel Puump
Old Sep 4, 2008 | 08:11 PM
joaoperez55's Avatar
Default LS7 Fuel Puump
Hi,
I'm from Brazil, and I have a LS7, a crate engine. This engine will run the 505hp original.
I have some questions about the fuel line:
-What is the work pressure of the fuel, for this engine?
-What is the flow of fuel?
-Do you recommend any external fuel pump, fuel regulator?
I'm thinking to buy those things on Summit, so, if possible, please tell me products that I can find and buy on Summit.
thanks a lot for the help
Best regards
Gabriel
Old Sep 4, 2008 | 09:30 PM
Lonnies Performance's Avatar
LS1TECH Sponsor
Base pressure is 58psi.
A single 255lph pump is all you need if the engine remains at 505hp.
Old Sep 5, 2008 | 09:18 AM
Thanks for this info.
Do you know if the LS7 Controller Kit 19166567 http://www.crateenginedepot.com/stor...7-P2219C0.aspx controls the fuel pump?
What fuel pump can you recommend?
Thanks
