no drive side fuel...
Old Sep 7, 2008 | 12:48 AM
scottie dont's Avatar
Default no drive side fuel...
i have a 98 trans am i just put in a heads, cam, intake, tb, exhaust, etc etc. i started it up and it wont run on its own but if i get it started and try giving it some rpm it'll get a lil fuel to the driver side. the driver side header is cold to the touch and i cant even get close to the passenger side header. i've tried 2 harness's and 2 computers and still no fuel. any help is greatly appreciated. thanks
- Scottie
Old Sep 7, 2008 | 11:53 AM
anybody?
Old Sep 7, 2008 | 03:06 PM
poconojoe's Avatar
Is there power on the injector plugs? The PCM fires the injectors by grounding them, so you need power going to one side of the plug.
Old Sep 7, 2008 | 03:16 PM
Omega's Avatar
Are you sure it's fuel? Have you checked for spark on the dead side also?
Old Sep 7, 2008 | 08:52 PM
slow's Avatar
I believe there is a fuse for each side of the engine, either fuel or spark, not sure which, but the guys who swap ls1's into v6 cars have a similar issue, and they have to add some wires to the body harness.
Old Sep 8, 2008 | 12:16 AM
yea i had spark. when i was leaving i thought there was a fuse for each side. when i got there this morning the first one i pulled was blown. fired it up wont idle still. cams to big for stock tune but after 1300 rpms it runs fine.
Old Sep 8, 2008 | 02:27 AM
Mean Green z28's Avatar
good to see you fixed it (did you?), did you have to pull the plugs and check if they're fouled?
