verfiying correct injectors for my setup
Old Sep 17, 2008 | 08:37 PM
chetmo's Avatar
Default verfiying correct injectors for my setup
http://www.byunspeed.com/product_inf...e1fd7db1a17d51
this is the style i need correct? and this should suffice for 420~ horsepower on motor at the wheels?
Old Sep 18, 2008 | 11:30 AM
chetmo's Avatar
anyone? i need to order these things today.
Old Sep 18, 2008 | 11:35 AM
ZL1Killa's Avatar
well first of all that link isn't working properly.
could you please just type what injectors they are and their ratings.
I'm guessing 42# injectors would suit you fine. Juicy juice being N20? wet or dry kit?
you want high impedance
Old Sep 18, 2008 | 02:25 PM
chetmo's Avatar
they are 30lb ford injectors. And it's a wet kit so only motor numbers matter. I did a calculation and it looks as if 35 lbs will be 80 percent. The injetors looked like the fat Bosch ones not the skinny injector.
Old Sep 18, 2008 | 02:38 PM
Adam @ New Era's Avatar
you might be better going with 42# injectors. you are stretching yourself a little on those 30's.
I've got lucas 42's in stock ready to ship for $290 out of the box, $330 for a flowmatched set.
-Adam
Old Sep 18, 2008 | 03:23 PM
chetmo's Avatar
pm sent.
Old Sep 18, 2008 | 07:46 PM
ZL1Killa's Avatar
good you are set. 42# injectors will do you good 42# is about the all around injector for up to 500HP
