How to test 42lb Lucas Injectors?
Old Sep 19, 2008 | 09:51 PM
Monello's Avatar
Default How to test 42lb Lucas Injectors?
Car seems to be misfiring a bit.
Need help!
Replaced plugs, wires, cleaned MAF, replaced Injector Orings.
Here is a few logs
misfire 1 and 2 are before the plug/wire change
misfire 3 is after the plug/wire change/maf cleaning.
misfire 4 - i flashed to an older tune to see if it was the tune.
File Type: hpl
File Type: hpl
File Type: hpl
File Type: hpl
Old Sep 19, 2008 | 10:11 PM
ZL1Killa's Avatar
do you have a cam? or just the turbo? did it do the misfiring anytime after the turbo install? have you been getting oil into your intake tract a lot?
I did a cam install and had to modify my misfire threshold tables, I do NOT believe that you need to do this as you don't have a cam, but just putting it out there.
Old Sep 19, 2008 | 10:47 PM
Monello's Avatar
I believe that there is oil in the intake. Stuck my fingers in there and they were black when I pulled them out, wet with a bit of oil.
Think im going to buy a pill for the turbo oil feed, i beleive it may be pumpin to much oil into the turbo.
Also, I never had a misfire until 2 weeks ago. So maybe the oil has finally began to build up in the intake?
Old Sep 20, 2008 | 12:11 PM
ZL1Killa's Avatar
ok...a bit of oil versus your fingers coming out black.... define more please. lol.
there should be a thin layer there...regardless of what you do that will probably happen, but to stick your fingers in there and they come out BLACK and coated... thats not good
