97 vette fuel rail swap
Old Sep 24, 2008 | 05:29 PM
ddcarter's Avatar
Default 97 vette fuel rail swap
I have a 97 corvette with return style fuel rail. I am changing the engine out for a LS7 based 427. Should I change this system out to the newer style or will this be sufficient?
Old Sep 25, 2008 | 11:23 AM
Nasty N8's Avatar
It will be fine you just need to modify it a little. Which intake manifold are you running?
Nate
Old Sep 25, 2008 | 05:25 PM
ddcarter's Avatar
I am thinking about using a LS7 with LS7 heads. If I dont go that route it will probably be L92 with L76 of comparable.
Old Sep 28, 2008 | 06:04 PM
ddcarter's Avatar
Will this rail fit on a LS7 intake?
Old Sep 29, 2008 | 10:52 AM
Nasty N8's Avatar
No the stock 98 rail will not fit that intake. We make billet rails that will fit those intakes. What car is it going into? Give me a call I will be able to set you up with the correct parts you need to make it work.
Nate
Old Sep 29, 2008 | 02:39 PM
ddcarter's Avatar
Nate
It is going into my 97 C5 vette. I am going to run a LS7 intake but have the return style fuel rail.
Old Sep 29, 2008 | 05:51 PM
7845's Avatar
i had a 97-98 vette fuel rail for my old combo. i went with a L76 intake and was able to reuse the 97-98 vette rail to work with the L76 intake. i tweaked the mounting tabs alittle and added a nylon spacer to take up the distance.
sorry pic isnt the best quailty but you can see how it works
