Are These Injectors?
Old Sep 27, 2008 | 04:53 PM
LT1 TRANSAM's Avatar
Default Are These Injectors?
Are these injectors HI OR LOW IMPEDENCE ? Any help would be great the part number is B5ZE-A3A
Old Sep 27, 2008 | 05:01 PM
FICINJECTORS's Avatar
on the opposite side there should be a number that starts with 0280------.. if you can get thqat I can tell you. or you could get an ohm meter and check it yourself. low would be 3.8+- high would be 12.8 to 16
Old Sep 27, 2008 | 09:56 PM
Thats Thde Only Numbers That I See On Them.
Old Sep 27, 2008 | 09:57 PM
I'm sorry the numbers are E5ZE-A3A
Old Sep 27, 2008 | 10:31 PM
THE INJECTOR IS A 35LB RATED AT 37PSI low impedance used on the 2.3 ford turbo engines. you can go to page 57 of this pdf to view all the specs on this. If you can't use them let me know. I can use them
http://www.fuelinjectorconnection.co...flow_rates.pdf
Old Sep 27, 2008 | 10:46 PM
I'm building a 383 stroker and my computer is set up for 36lbs injectors and do i need low or hi impedence?
Old Sep 27, 2008 | 10:56 PM
an LT1 383 that is and i dont know which i need for the motor as i said the computer is set up for 36lbs injectors thx in advance
Old Sep 28, 2008 | 08:41 AM
if you are using a gm computer you must use high impedance injectors..
