what size gear?
Old Oct 20, 2008 | 09:54 AM
ERVNZ28's Avatar
Default what size gear?
I bought a rear end housing at a Salvage Yard for $50 and it had the axles, gears, and brake drums all still on it. I'm just curious as to what size the gears are...the pinion gear has 12 teeth and the ring gear has 40
Old Oct 20, 2008 | 10:18 AM
FSTR/TA's Avatar
Default 3.23s
If you counted correctly it shows you have 3.33s which don't exist. Trick, use a white chalk or grease pencil and mark the first tooth you count on the ring and pinion and count from there so as not to double count or miss a tooth. My guess though is 3.23's which is the performance axle ration for Automatics. 2.73's are the regular option and 3.42 come with 6 speeds.
