Used Gears Whining
Old Oct 25, 2008 | 02:45 PM
b4c346's Avatar
Default Used Gears Whining
hello.i bought a used set of gears 3.73 and got them professionally installed.gears are g.m. out of a camaro.they are whining at a steady speed and coming to a stop.my installer said all the tolerences were correct and have a good pattern.the bearing that came on the pinion looked really good.also a new crush sleeve was used.i'm bringing it back for him to re-check it tomorrow.anyone else had trouble with used gears.probally going to order some new g.m. gears and get them installed.guess that's what i get trying to cut corner's.
Old Oct 25, 2008 | 04:01 PM
03 BUSA's Avatar
Depending on the brand and how tight it was setup? I built my gear with a guy at work that does it everyday. He set it up with .008 backlash for drag racing and said it is going to make some noise. I did not pay full price for this stuff but I can tell you there is over $2600 in parts in my center section alone and I already know it is going to make some noise. Part of the game I guess.
Old Oct 26, 2008 | 02:22 PM
CW00BlackTA's Avatar
I had a local pro set mine up and he had to do it 3 times until it stopped whining. Sometimes it's a little trial and error--even though the pattern looks good.
Old Oct 26, 2008 | 04:49 PM
cabel1's Avatar
That's the problem using used gears. They get a wear pattern on them from use. When you put them in a different rear if they aren't set up exactly the same they will be at a different spot and make noise.
Old Oct 27, 2008 | 11:24 AM
b4c346's Avatar
thanks guy's for your reply.kinda thought the same thing with the trial and error.brought the car back yesterday and hoping it works out.
