Moser 9" question
Old Nov 20, 2008 | 02:52 PM
mikez28_mjf's Avatar
Default Moser 9" question
I got a Moser 9" with the back brace in my car. I am having trouble getting the sway bar to work. I am able to get it mounted, but the sway bar is not "big" enough to work. Does anyone have any ideas what I could do to get a sway bar to work?
Also, add that it looks like unmodified u-bolts were used and that there is no back brace. Is that so?
The center part of the sway bar is hitting the axle the way that I can put modified bushing mounts on the axle.
The car is 97' Formula with a LS1 crate engine.
Thanks!
Old Nov 20, 2008 | 03:01 PM
EPP's Avatar
EPP
It should fit just like this one. Bob
Old Nov 20, 2008 | 03:14 PM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
Do you mean the mounts you've got are too big for your swaybar?
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old Nov 20, 2008 | 03:27 PM
guys, thanks for the replies but the car is a 97' Formula, I edited my original post.
Old Nov 20, 2008 | 04:17 PM
BMR Tech2's Avatar
Thanks!
We offer a sway bar mount kit for aftermarket rearends. We offer it with bushings and hardware or no bushings. Call if you have any questions. Here is a link to our site.
http://www.bmrfabrication.com/F-bodySuspension.htm
__________________
T.C.
Sales Pro
BMR Suspension
(813) 986-9302
Like us on Facebook!
Old Nov 20, 2008 | 04:30 PM
EPP's Avatar
EPP
It would be the same combination, whether it is an LT1 or an LS1 as far as the rear and the sway bar goes. Bob
