Bad Gears
Old Nov 22, 2008 | 11:01 PM
Inspector12's Avatar
TT-TECH Veteran
Default Bad Gears
Bad Gears. How many people have run into this I have a set now that are off just enough to cause a vary slight whine on decell not bad at all, but I expect total silence with my gears and have always had that so I decided to re-check the set up on the gears etc... And found them to have a hard spot so checked the run out on the center section and it was perfect and well the rear was dead silent before with the 3:73's so I figued that so any way just wondering what kind of things you guys had run into.
