which rear??????
Old Sep 25, 2003 | 12:55 AM
wicked383bird's Avatar
Default which rear??????
well i am pretty sad right now, after installing my 383 stroker with heads and cam in my 95 ta, today i go from 1st gear to a second gear shift, and BOOM! the rear end is shattered! I am not financially fit to afford a 12bolt or 9", do you guys think i can rebuild the 10 bolt to hold this motor setup? if so what should i internals should i use or what can you friends reccomend? If not what rearend should i go with, and can you guys refer me to a good place? thanks guys i really appreciate it...if i cant afford it the birdy is gonna sit outside for a while :*(
