need some help
Old Dec 25, 2008 | 01:27 PM
19mike84's Avatar
Default need some help
ok so my door codes say my car came from the factory with 3.23's but i have a feeling the rear end is from a junk yard. is there anyway i can tell a 3 series between a 2 series by looking at the diff.?
Old Dec 25, 2008 | 02:17 PM
jsteele90's Avatar
does your traction control and abs work?
Old Dec 25, 2008 | 10:08 PM
19mike84's Avatar
abs doesnt work and i dont have trac cont
Old Dec 26, 2008 | 12:23 AM
01ssreda4's Avatar
do a search for cruise speeds vs. gear vs. rpm. my 3.23 cruises in OD at 68 at 2K even with the 4L60e. or you could jack the car up and spin the driveshaft and tire and count the turns.
Old Dec 26, 2008 | 12:54 AM
jsteele90's Avatar
sounds like a 2 series carrier then
Old Dec 26, 2008 | 12:39 PM
19mike84's Avatar
yeah i was thinking it was a 2 series, it does have a spacer between the ring gear and the carier
Old Dec 27, 2008 | 08:19 PM
19mike84's Avatar
change, it does not have a spacer behind the ring gear
