which gears...
Old Jan 29, 2009 | 07:54 PM
4.6what's Avatar
Default which gears...
...have you guys had the best luck with not breaking? i want a set of 4.10's for my stock t/a. my car only has 57k miles on it so i'm not going internal any time soon and making huge power so i dont see the need for a 9" yet. i was just wondering which brand seems to hold up the best. should i get a new posi while i'm in there? or just the gears?
Old Jan 29, 2009 | 08:30 PM
jetlag's Avatar
I wouldn't waste money on a new posi...if you want some gears, just pick a brand and go for it.
They are all equal really, it's the small size that is the reason for breaking. Especially with a 6spd, just start stashing some money under your pillow for the new rearend.
Old Jan 31, 2009 | 04:17 PM
4.6what's Avatar
oh okay..
Old Jan 31, 2009 | 04:30 PM
4.6what's Avatar
i think i'm going with richmond. What else is required for the install? i know cover gasket, pinion seal, crush sleeve, pinion shims, pinion nut.. are new ring gear bolts required or recommended? how about carrier shims and bearings and pinion bearing?
Old Jan 31, 2009 | 08:08 PM
jetlag's Avatar
For the cover gasket, just use RTV. Usually the install kits will come with near gear bolts. You can use them or not. I didn't. I went with a solid spacer instead of a crush sleeve.
You can buy the full install kits here... with all bearings and everything needed.
http://www.speedinc.com/catagory.cfm.../%20Driveshaft
Old Feb 1, 2009 | 10:34 PM
4.6what's Avatar
i was looking at the ws6 store and the install kits they offered. i didnt know which one i needed to buy with the new gears
