Moser 12 bolt install how to..
Old Mar 3, 2009 | 02:17 PM
bow125106's Avatar
Default Moser 12 bolt install how to..
I thought i remembered the other day coming across a thread that showed a step by step on removing the 10 bolt and installing aftermarket rear....I have searched and searched and now cannot find it.....Can anyone help me out with this or lead me in the direction of a good how-to that includes pictures..?
Thanks
Old Mar 3, 2009 | 02:25 PM
BlackScreaminMachine's Avatar
Internet Mechanic
its not too hard to be honest, I am at work and I cannot do a step by step here but....
1) Remove old rear
2) Take caliper brackets off old rear
3) take axles to a shop and have the brackets put on and then the bearings pressed in
4) Buy a sway bar kit with bigger clamps for the axle tubes, 3" muffler clamps work, or Spohn sells a kit
5) IF using a BMR tq arm grind off the 1st set of TQ arm hole and use the 2nd set.
6) Buy a DS with the proper u joint or modify the stocker. ( would recommend getting a better unit)
7) get the appropriate fluids for the rear and diff additive if a posi
8) Follow break in proceedures provided by moser.
Here is one I used....
http://www.fbody.com/tech/details.cgi?id=3
http://www.fbody.com/tech/details.cgi?id=13
