9'' Still vibrating
Old Mar 9, 2009 | 05:43 PM
RamAir02TA77's Avatar
Default 9'' Still vibrating
Got my driveshaft lenghtened and obviously balanced at a local place its definetly vibrating less but there is still some vibration. Im hoping/guessing setting the pinion angle is gonna solve all the vibration. This car had little 2 no vibration when I had the 10 bolt in. I ordered an adjustable phb so I can push the rear of the car over alittle as its alittle out but thats probably not going to do anything. Ive done a search on the best way to set the pinion angle but ive got a bunch of different results. I have the umi adjustable tunnel mounted torque arm from what I gathered the best way to set pinion angle make sure the car is level with the rearend loaded?
Old Mar 9, 2009 | 05:58 PM
EPP's Avatar
EPP
http://www.bmrfabrication.com/INSTALL/XTA001.pdf
Check out BMR's method at the above link. Bob
Old Mar 9, 2009 | 06:05 PM
Thanks yeah I talked to Jeff from jaws gear and im going to try and setup the pinion angle I believe I have it pretty far off.
