10 bolt info needed
Old Mar 29, 2009 | 10:29 PM
mg98ta's Avatar
Default 10 bolt info needed
I need ta know the width of the F Body rear ends. LT1, LS1, and the V-6 car rear ends. Outside measurement (outside of brake rotor or brake drum) where the wheel mounts. I have a 98 LS1 car (it needs a rear) and found a drum brake rear out of a 95 V-6 car. Can I swap my brakes over on it and use it? I remember reading about the LT1 and LS1 axles being different lengths. What about the V-6 car's? So I need ta know: outside width of the rear end, difference in length of LT1, LS1, and V-6 axles, and can disc brakes be swapped over to a drum brake housing. All info will be greatly appreciated.
Thanks, Mike
Old Mar 30, 2009 | 11:03 AM
mg98ta's Avatar
Anyone?
