finding a 9" or 12 bolt for 87Z
I know he took his old 10bolt and tack welded it onto a metal covered table and then cut off the brackets on the 10 Bolt and the put the 9' ontop of it and the welded the brackets back on.
But remeber you want to buy new axles, gears,center section for your housing plus you have your C-clips etc. etc.
Like I said your still going to spend money and it's not hard to find a housing but it will consume alot of your time.
Hope this helps a little
Or another alternative would be to find a complete 9" that is long enough from a auto recycler, then have the axles/ends cut to the proper length, cut off the old brackets and weld on your new ones.
Either way would require a shitload of work
Mike
