Trying to assemble 9"
Old Apr 18, 2009 | 06:21 PM
vettett15's Avatar
Default Trying to assemble 9"
attempted to assemble my 9" center section today and ran into some problems. I have everything in there and went to check/set ring gear lash but the ring gear is hitting the housing and the lash is .018 which means I need to move the ring gear in but that would make it hit the housing even worse.
If I were to move the pinion in more that would help but I only have one shim between the pinion support and the housing.
It almost seems like the housing needs to be clearanced some.
I got all the parts from QP except the differential.
Anyone have any experience with the Yukon housing?
Yukon Aluminum Housing
Motive 4.11's
Ford Track Lok
Solid Pinion Spacer
Daytona Pinion support
thanks,
pete
Old Apr 19, 2009 | 05:52 PM
Mikey 97Z M6's Avatar
I'm trying to understand what you wrote so forgive me if I'm reading it wrong.
If you tighten up the backlash it should be moving closer to the pinion, and away from the housing. Backlash should be around .008 to .012. Where on the housing is it making contact at?
What is your pinion shim thickness? Sounds like you might need a thicker shim to move the pinion out away from the ring gear.
Mike
Old Apr 19, 2009 | 06:07 PM
01ssreda4's Avatar
can you post a pic. and yes with a .018 backlash you would need to move the gears closer together.
Old Apr 19, 2009 | 07:59 PM
vettett15's Avatar
Sorry for the confusion, the ring gear is hitting the front pinion support of the housing, so it is the actual teeth of the ring gear hitting. So the closer I move the ring gear to the pinion the worse it will get but this is required to get the right backlash (cause i'm at .018 now). Right now I believe I have around .020 for pinion shim thickness (I was just guessing and then going to see what the gear pattern looked like and adjust accordingly). Ive read on a couple other forums that trimming the housing some is a more common thing than I would have thought. I'm going to give QP a call tomorrow and see if they've had to do that on the Yukon aluminum housing before. I'll try and get some pictures tomorrow.
Old Apr 19, 2009 | 11:55 PM
OK, so have you tried adjusting the carrier to where it won't rub on anything, then insert the pinion assembly without a shim?
Mike
Old Apr 20, 2009 | 05:51 AM
vettett15's Avatar
I thought about it but then I assume that would screw up my pinion depth.
Old Apr 20, 2009 | 12:07 PM
vettett15's Avatar
Spoke with a guy at QP today, he said that yeah you have to shave, made it seem like it was no biggie and they do it all the time. Guess I know what I'm doing...
