Pinion Angle!! Please Help!!!
optimal pinion angle is desired to properly phase the u joints. if the engine and tranny are pointed down 3* towards the rear of the car and you set your pinion at 3.5* down towards the front of the car then you have effectively placed 6.5* into the joints which is tooo much. Under load at ride height you want the joints phased as close to neutral as possible to remove harmonics. You put negative degrees into the pinion to take into account chassis/suspension component flex and slop.
read these stickys and they will help you out a lot they helped me understand a lot about seting up pinion angle and so on.
i go by madmans way to set it.
hit the link.
https://ls1tech.com/forums/drag-raci...-me-first.html
