2 Questions after 9" install
Old Apr 30, 2009 | 07:27 PM
RHYNO6.0's Avatar
Default 2 Questions after 9" install
Does anyone have a link for bleeding brakes? I bleed them but they still aren't 100%
There is a noise coming from the pinion maybe or that general area and I have no idea what it is. Kind of a squeak with each rotation. Has anyone had this problem and also how tho you set the pinion angle without that tool from BMR? Adjusting the torque arm quites the noise a little it but it never stops fully.
Old Apr 30, 2009 | 07:59 PM
SILVER SS 00's Avatar
got a question for you. did you put it together,if so how far did you press on the bearings
Old Apr 30, 2009 | 08:57 PM
EPP's Avatar
EPP
http://www.popularmechanics.com/auto...o/4213448.html
Link to bleeding brakes.
Pick up an angle finder from your local hardware store ($4.99 at Sears) to adjust the pinion angle. You could have a u joint that is squeaking, which can happen if a needle bearing is out of place or if one of the caps was tightened down too tight. Bob
