9" conversion ?'s
Old May 2, 2009 | 06:40 PM
Blake02SS_7's Avatar
Default 9" conversion ?'s
have a 02 ss, has the junk 10 bolt 7.5" in it i just shelled it last night haha, im looking at the morso 9" complete differentals on texas speed ready to bolt in a go basically. couple of questions:
1.) will i need to shortin my driveshaft or will it bolt right up?
2.)what spline should i go with and does that matter what carrier i use with a certian spline number?
3.) or is there a link or website i can look at that can give me information on all this stuff?
Old May 2, 2009 | 07:15 PM
EPP's Avatar
EPP
http://www.exoticperformanceplus.com....html?item=145
I have a lot of information at the above link. The stock driveshaft will work but you will need a Napa 447 conversion U Joint. In reality the driveshaft should be one inch longer, for most people this is not a problem, a few have experienced a vibration that required the longer driveshaft.
I would go with the Truetrac with the 31 spline.
If you have any other questions, shoot me a pm and I'll help you out. Even if you don't buy it from me. Bob
Old May 6, 2009 | 09:51 PM
cool thanks bud one more question that rearend should bolt right up to right? as far as shock mounts and everything.
Old May 8, 2009 | 05:13 PM
Pharcyde50's Avatar
Yeah bolts right up. I welded on the perches for the e brake.
Old May 9, 2009 | 06:08 AM
EPP's Avatar
EPP
Yes indeed, everything bolts right back up. I have step by step instructions at this link.
http://www.exoticperformanceplus.com....html?item=145 Bob
