QP 9" housing studs
Old May 4, 2009 | 07:32 PM
vettett15's Avatar
Default QP 9" housing studs
Hey,
Started to assemble my 9" housing as much as I can inside my apartment. How have you guys been installing your housing studs, I can get the stud started in the housing by just using the nuts supplied by I run out of threads. Do you pull the studs up the rest of the way when you have the third member on? Also they gave me lock washers but I have an aluminum center section, aluminum on lock washers is a big no no so I suppose I'll get some flat washers. I assume the lock washers were for iron third members?
Old May 4, 2009 | 07:43 PM
BarneyMobile's Avatar
you could always use the lock washers ontop of a flat washer
Old May 6, 2009 | 10:49 AM
TJ's Avatar
TJ
you need to get some washers and a spare nut and run the studs in all the way before you bolt up the center section.
you NEED to use those lock washers unless you use locknuts, which are a total pain in the *** when you are under the car.
you will have to get sae type flat washers, as some of the std USS type flat washers may be too large in diameter to clear some portions of thd case. i may be wrong, but it would be good to have them for extra insurance.
