wrong u-joint part #'s in search. help
Old May 11, 2009 | 11:15 AM
2camaros6702's Avatar
Default wrong u-joint part #'s in search. help
I did a search and found a few good threads or so I thought for u-joint part #'s. I am putting a moser 12 bolt in with a stock drive shaft.
I just went to Napa and got the P447 and it was NOT the correct u-joint, I went back and got the Precision 348 that Napa has and it is NOT the correct one although it does fit the yoke (cap size and length) it does not fit the drive shaft. The stock cap is 1.122 in diameter and the cap on the 348 is 1.188. Any other suggestions!!!!!!!!!
I now have my car in the driveway with no rearend under it. HELP
Old May 12, 2009 | 05:22 PM
camscam02's Avatar
this is what I used about a year ago, got from napa
1310-1350 u joint part number:
Napa- 240-0447x or,
Precision- 447
U bolts to hold driveline to rear.
Precision- 330-10
These are what is need to mate stock driveshaft to 9inch ro 12 bolt with a 1350 yoke on the rearend.
Old May 12, 2009 | 08:39 PM
EPP's Avatar
EPP
The Napa number now is just a 447, they changed it at some point last year. Bob
Old May 13, 2009 | 06:16 AM
Thanks guys.
