Something wrong with my driveshaft?
Old May 13, 2009 | 12:49 AM
firechicken76's Avatar
Default Something wrong with my driveshaft?
when i did my 9" swap a few months back we had to pull the driveshaft out, when i was packing it around i felt something slide on the inside, i turned it upside down and it slid the other way, kind of like tenis ball in a tube, i believe the shaft is out of an 02 fbody, but it says something about about 3 rivers or rivers on it, so im not sure if its stock or aftermarket. either way has anyone ever heard of this in a driveshaft? could it be bad on anything or affect the balance of the weight?
Old May 13, 2009 | 11:41 AM
no one? i searched and found the 3 rivers shaft to be stock, but havent found anything about the piece moving inside the shaft.
Old May 13, 2009 | 12:26 PM
Intercooler2's Avatar
It's probably the cardboard inside. Search for broken driveshafts and you should find a pic
