moser axle ????
Old May 13, 2009 | 09:50 PM
robsquikz28's Avatar
Default moser axle ????
can a moser axle that was originally sold as a 3 channel axle be converted into a 4 channel axle...im guessing its the same exact axle With out the reluctor rings on both axles! if thats the case then I would assume you can convert the axles to 4 channel just by simply putting the abs rings on...or just eliminating the abs completely with a abs delete kit...
Old May 14, 2009 | 05:02 AM
EPP's Avatar
EPP
Yes, the only difference is that the end of the axle will need to be machined for the reluctor ring. If you just use the axles as is, you won't have ABS or TCS. The ABS wouldn't work then on the front of the vehicle either, which wouldn't bother me as I don't care for ABS brakes. Bob
Old May 14, 2009 | 01:15 PM
but then you would need the abs delete kit, correct?
Old Aug 6, 2009 | 12:26 PM
rggbly's Avatar
well what exactly has to be machined?
Old Aug 7, 2009 | 09:06 AM
rggbly's Avatar
can someone tell me what has to happer to have the reluctor rings pressed on? can a regular machine shop do it?
