MWC 9" install: E-brake cable configuration question
Old Jun 6, 2009 | 11:01 PM
Weezzer's Avatar
Question MWC 9" install: E-brake cable configuration question
The original configuration on the E brake cables is:
1. Two cable bracket guides on the PS (eyelets made from what looks like ¼” diameter steel rod - bent in a square or box shape that the E cable threads through), one connected to the 10 bolt pumpkin cover on the PS & one connected to the outboard PS portion of the axle.
2. One eyelet on the DS connected to the DS pumpkin cover.
I've gotten my MWC&P 9" mounted and will connect the E brake cables tomorrow. Off-hand it looks like these cable brackets won't be needed on the new rear end.
Anyone re-mount these on the fabbed 9" or is the board preference to just leave these off all together?
Thanks
Old Jun 7, 2009 | 04:56 AM
RA4926's Avatar
i left them off on the 12 bolt. if you choose to do thee same just make sure the cables stay away from rotating or passing objects.
Old Jun 8, 2009 | 10:10 AM
Bad30th's Avatar
You don't need the factory ebrake brackets, the MWC rear comes with them.
I used nylon pullties to secure the ebrake cables and ABS wiring together and tied them to the rear near the center section, and looped them around to both sides.
Here's a pic from my install :
Rob (Bad30th)
