4l80 conversion U joint
Old Jun 13, 2009 | 12:09 PM
Rickys S/C Z28's Avatar
Default 4l80 conversion U joint
hay guys any one know were i can get a 1410/s44(3R) u joint or have a part number?
Old Jun 14, 2009 | 02:31 PM
ssvert99's Avatar
LS1Tech Premium Sponsor
depends on the trans yoke you are using. I have had good luck finding the correct ujoints in stock at Oreilly auto stores. Precision brand 447 is the correct one to swap from the stock shaft to 1350 series, which is the most common.
Old Jan 12, 2010 | 04:38 PM
bhop42's Avatar
Did you ever find this joint? I need one also.
