Dyno effects
Old Nov 12, 2003 | 11:20 PM
Z06PSI's Avatar
Default Dyno effects
Just wondering how gearing effects dyno measurements..... not a dyno queen but just wondering how it effects actuall hp and tq measurements...??????
Old Nov 13, 2003 | 01:51 PM
x phantom x's Avatar
STF veteran / 10 second club
Depends on what gearing you have, but generally a numerically higher gear will show lower results on a dyno. For instance, if you have 3:42's stock, and pull 300 hp, put 4:10's in, you might pull 290-295 hp.
Old Nov 13, 2003 | 11:51 PM
Screamin_Z's Avatar
not me, I had 3:42's then put in a 8.8 hybrid w/ 31 splines and 4:10's and didn't lose ANY HP or TQ...
Old Nov 14, 2003 | 07:48 AM
9T9BlueTA's Avatar
It will usually show lower because you are not dynoing at a 1-1 gear ratio anymore. But its not that much and depending on weather and condition dynos can vary by about 10HP anyway. I wouldnt care if the gears showed me losing 40HP the car is so much more alive with them.
Old Nov 14, 2003 | 12:33 PM
Screamin_Z's Avatar
yeah, no one has really lost HP, ur engine is still putting out the same. but u do have more get up and go from the gears.
Old Nov 14, 2003 | 02:45 PM
z98's Avatar
z98
I thought it was the other way around
Old Nov 15, 2003 | 04:22 PM
trackbird's Avatar
This may help.....
https://ls1tech.com/forums//showthread.php?t=9518
