12 bolt fitment
Old Jul 22, 2009 | 11:25 AM
JRock15's Avatar
Default 12 bolt fitment
Will a 12 bolt that has been in a 95 z28 fit in a 99z without any problems? Just wondering, I have found one used that I can pick up at a good price.
Old Jul 22, 2009 | 11:26 AM
JRock15's Avatar
it is a Moser 12 bolt as well.
Old Jul 22, 2009 | 11:51 AM
BlackScreaminMachine's Avatar
Internet Mechanic
My understanding the GM 10 bolt was the same in the S-10 that was unsed in Fbodies. a 12 bolt compared to a 10 bolt is the same length as I have noted no real difference.
I would just check to make sure it wasnt modifed by the prev owner, as some racers shorten rears to fit bigger rims and slicks etc etc.
Also you may want to ask if it comes with ABS and if it does, is it set for a 3 channel (w/o traction control) or 4 Channel (w/ trac. Control)
Old Jul 22, 2009 | 11:53 AM
BMR Tech2's Avatar
LS1Tech Premium Sponsor
Hello, yes it should fit fine. All of the brackets are the same its a direct bolt in.
__________________
T.C.
Sales Pro
BMR Suspension
(813) 986-9302
Like us on Facebook!
Old Jul 26, 2009 | 09:39 PM
JRock15's Avatar
yeah, everything is the same length and the ABS is the same. The other questions i have are that the 10bolt has long bolts that connect the torque arm all the way through. On this 12bolt will 4 1/2in thread bolts connect the torque arm now? The long bolts will not go through it because of the housing shape.
The other question is there are already lt1 backing plates on it. Will the LS1 backing plates swap out with no problems?
Thanks!
