Best angle for adding rearend fluid?
Old Sep 10, 2009 | 10:43 PM
Bpjr07's Avatar
Default Best angle for adding rearend fluid?
lately i have been noticing that the rearend has left a few drops now and then after a hard racing/launching
i was wondering what would be the best angle to have the rearend in when just adding fluid do i need the front on the car up too and do i need to lift the car from the chassis or the rearend? thanks
Old Sep 11, 2009 | 06:59 AM
Intercooler2's Avatar
You just want the rear level front to back and side to side. You probably have a pinion seal leak which will always be like that.
Old Sep 13, 2009 | 11:55 AM
INMY01TA's Avatar
Sears, K mart, Home Depot, all sell a red plastic pump for about $10. Comes with long red hoses you just stick in there and pump it in.
Old Sep 13, 2009 | 12:00 PM
venom1997's Avatar
put the car up on stands front and rear and try to get it close to level as possible.
Old Sep 25, 2009 | 02:41 PM
ssmylez35th's Avatar
it does sound like a pinion seal might be leaking and the best way to put fluid in without putting it on a hoist is a small pump like INMY01TA had mentioned, i had the same problem and that what i did with a lil pump!
Old Sep 28, 2009 | 12:49 PM
Troy's Avatar
Once the rear is basically level, you can do like I did, I have a chrome cover made which has a hole and fitting tapped into it to just add the fluid without trying to wedge something up from over the top and making a mess.
