C-Clip problems-10 bolt- HELP !!!
Old Sep 12, 2009 | 06:13 PM
5.7iroc-02ws6's Avatar
Default C-Clip problems-10 bolt- HELP !!!
I have an 88 IROC I installed a 4th gen LS1 10 bolt in years ago--I decided to put in a set of moser axles and c-clip eliminators... got it all installed tonight (cut the housing) and to my surprise--my LS1 rear brakes won't work ! The axle is too far 'out' by about 1/2 an inch and when you slide the rotor flush to the axle and attempt to get the brake caliper bolted up--it won't reach the backing plate---it's like the axles moved out 1/2 inch w/the eliminators... Either I have the wrong eliminators or I need a different backing plate....
Anybody encounter this or even try this before?
Ryan
Old Sep 12, 2009 | 09:24 PM
Intercooler2's Avatar
Did you check the new axles for length compared to the others? I'm not familiar with the 3rd Gen axles but the 4th's have more of a wedge than a c-clip. Maybe you ordered LS1 and actually got 3rd Gen which more than likely takes the clips that go around about 1" from the end.
Old Sep 12, 2009 | 09:46 PM
I'm going to check the part #... I didn't set the axles up next to each other. I ordered the axles for the 4th gen rearend.. I don't think that's my problem as it just appers the aluminum plate for the c-clip elim's are too thick... Anybody running a 10 bolt with c-clip elims? No brake problems? Did the kit come w/a brkt to relocate the backing plate/brakes?
