Big studs on stock wheels
but, for a stock wheel, 1/2" is going to be the most common available with lugnuts to fit the stock wheel without mods.
he machined his rims out and runs 5/8 studs on the back.
runs 8's on 17"
its a pretty sweet ride.
i guess it would depend on how much material of the wheel you could cut out and be safe.
first is stud 5/8" stud in stock rim
second is stud and nut in stock rim
third is socket over stud in stock rim
so does this mean a 5/8 will work in stock rim?
you would have to machine the inside of the rim flat so the washers could sit on it.
OR
you could get real trick and have some washers made that look like a nitrous jet so you wouldnt have to machine your wheel.
you could use the reg washers on drag wheels at the track, and then throw your stock wheels on with no modifications if you ever wanted to unload the wheels.
moser gave me that idea. then on the street run 1/2 and when i go to track(two a year) run 5/8
on the other hand, thats a good idea to have them drilled for both so you dont have to pay for machine work later.
