12bolt leakage
Old Oct 6, 2009 | 02:12 PM
Shamson5.7's Avatar
Default 12bolt leakage
Ill see if I cant get some pictures, but as it sits in my garage right now the rear is leaking quite a bit. I put an oil pan underneath it and theres a few ounces of fluid in there. Has anyone else had problems with a leaky Moser? Could it be a pinion seal? I havent had much time at all to actually get underneath it, but was curious what the most common problems were.
Ive had it for 4 years and put about 45k miles on it. Didnt start leaking until I got back from my 2200 mile roadtrip.
Old Oct 7, 2009 | 06:52 PM
synner's Avatar
could be the pinion or the rear cover, my moser is leaking at the pinion, i have had mine in for a while and the leak has just started and it does have a whine to it
Old Oct 7, 2009 | 08:18 PM
SOMbitch's Avatar
If it leaks that bad I would guess cover. Pinion seal is very common but is just usually just a little wet at the front and you see nothing under the car....
A quick visual will tell ya.....
Old Oct 13, 2009 | 08:52 AM
99monguse's Avatar
Mine was leaking too. I had several issues though. Then vent hose was puking fluid out and the axle seals were both leaking but the passenger side was really bad. I had oil all over my inner wheels in the back. I only have only put a few thousand miles on the set-up since the install (which was about 4yrs ago)
Old Oct 14, 2009 | 11:22 AM
Shamson5.7's Avatar
So its looking like its coming from the bottom of the cover. It sat for 2 weeks and I got maybe an ounce of fluid from under it.
How hard is it to replace the seals on these without dropping the sway bar or panhard?
Old Oct 17, 2009 | 05:41 PM
LoudGM's Avatar
I can take mine off by just rotating it around and up until you get it just at the right angle to slip out. It's not bad at all.
