Can't Remove C-Clips
Old Oct 16, 2009 | 08:53 AM
u118224's Avatar
Default Can't Remove C-Clips
2004 Suburban 10 bolt. I decided to replace the rusted out backing plates while I'm doing the rear brakes. I removed the axle retaining pin but the axles won't slide in quite far enough to remove the c-clips. It's close, but not enough. I've read here and elsewhere that on traction control equipped vehicles, which this is, the TCS sensor should be removed to allow the axle to slide in a little further. I'll try that tonight.
My question is, why would the sensor inhibit the axle from sliding in further?
Thanks.
Old Oct 16, 2009 | 04:46 PM
theguyulove2hate's Avatar
The pick up on the sensor sticks out to far and hits the exciter ring. It should be a 10 MM bolt that holds it in. Pull off the sensor and you will be able to get the axle in far enough.
