moser rear end fluid
Old Nov 12, 2009 | 06:38 AM
z28drag's Avatar
Default moser rear end fluid
i have a moser 12 bolt 4.10, i need to change the cover gasket, its leaking. my question is what fluid should i use and should i use the additive....i put the rear end 7 years ago and i do not remmenber what i used.... also does any one know of a really good 12 bolt gasket. thanks......
Old Nov 12, 2009 | 08:14 AM
BlackScreaminMachine's Avatar
Internet Mechanic
I do not have my old paperwork infront of me, but it was a NON syn I think 75w type oil. I'll do a search. Just throwing it out there.
I just did a simple search, and Bob @ EPP came up with a close answer to mine.....
https://ls1tech.com/forums/gears-axl...ear-end-s.html
Enjoy.
Old Nov 12, 2009 | 06:05 PM
jimbo98z's Avatar
It depends on the type of differential that's in there. That will determine what type of gear oil you use, and whether or not you need additive.
If you have a True Trac, which a good deal of Moser's have, do not put synthetic in there. 75w90 or something thereabouts will be fine.
As far as gaskets, I've always had good luck with the Fel-Pro gasket you can pick up at any local parts store.
Old Nov 12, 2009 | 07:02 PM
EPP's Avatar
EPP
Moser does not want you to use synthetic gear oil in any of their rears. 80/90 weight non synthetic gear oil is what is to be used. Bob
Old Nov 15, 2009 | 11:36 AM
JFM-jr's Avatar
Would this Moser recomendation go with a spool as well? I just got my new ring/pinion from Jaws Motive gears and was wondering what oil to use. The rear is beyond comprehension noise levels as of now i'd like this new set to be as quiet as humanly possible.
Old Nov 20, 2009 | 05:25 AM
EPP's Avatar
EPP
Yes, they recommend non synthetic for all of their assemblies. Bob
Old Nov 20, 2009 | 09:54 AM
Apollo0526's Avatar
why don't they want you to use synthetic?
Old Nov 23, 2009 | 08:11 PM
z28drag's Avatar
thanks for the help......
