Broken Axle Shaft
Old Nov 14, 2009 | 04:34 PM
Ross T's Avatar
Default Broken Axle Shaft
Im not sure what exactly went wrong here??????
I was shifting from 2nd to 3rd around 22-25mph and i just popped out instantly. all the bolts came out at once. found 5 of them within 50ft of each other a block from my house
Attached Thumbnails Broken Axle Shaft-img_1051copy.jpg   Broken Axle Shaft-img_1047copy.jpg   Broken Axle Shaft-img_1045copy.jpg
Old Nov 14, 2009 | 04:52 PM
98pontiac's Avatar
were they stripped out? did you get the seal replaced recently? if they arnt stripped out someone forgot to tighten them otherwise that is a huge coincidence.
Old Nov 14, 2009 | 05:45 PM
Ross T's Avatar
huge coincidence!!!!... i just took off the right axle and its the exact same. the bolts are NOT stripped. i never found the 6th bolt [couldve came out months ago] but either way 5 came out within >50ft literally
