Clunking after 9 inch install
Old Dec 17, 2009 | 06:38 PM
greasess's Avatar
Default Clunking after 9 inch install
I just installed a moser 9 inch with 35 sp axles, a detroit locker, and a PST driveshaft with 1350 U joints and billet slip yoke. There is a clunking when i load/unload the drive line. It seems smooth when it's loaded and at a constant speed. Im not sure but i think it might be a u joint. Does anyone have any bright ideas?
Old Dec 17, 2009 | 07:54 PM
EPP's Avatar
EPP
The clunking is normal with a locker. It is not as noticeable with an automatic, but with a manual it will be more evident. Bob
Old Dec 17, 2009 | 08:05 PM
greasess's Avatar
Thanks bob. What is "dry hop"? I hear it's somthing i should do to engage the locker at the strip. idk
Old Dec 17, 2009 | 08:14 PM
DAVESS02's Avatar
Are you running a 6 speed? If so, you'll need to shift faster or more delayed then the norm. 6 speed synchros dont like the lockers. They start off getting notchy and then start grinding.
Old Dec 17, 2009 | 08:36 PM
02CamaroSSLE's Avatar
how does the locker in the rear end mess up he syncros in the trans?
Old Dec 17, 2009 | 08:54 PM
01FbTaWs6's Avatar
its def. the detroit locker. Mine clunks and bangs like crazy. But i sure as hell dont have to worry about breaking it
Old Dec 17, 2009 | 09:13 PM
Mean Green z28's Avatar
maybe 'cos it unloads and loads the rear end between shifts while the auto doesn't
Old Dec 18, 2009 | 06:11 AM
cambirdracing's Avatar
Don't do it. You will break something. It's after you do your burnout, you pop the clutch/mash the gas on an auto outside of the water box. Draag racers used to do it years ago, but discovered that it actually cools the tires back down and breaks stuff. More cars broke before the starting line than after it.
Old Dec 18, 2009 | 06:44 AM
greasess's Avatar
Thanks for all the replies. I do have a 6 speed. I guess i should have done a little more research before i went with a locker. I'm gonna try to live with it and see how it goes. Otherwise I'm thinking about a wavetrack. Anyone wanna buy a Detroit locker that's gonna have 500 break in miles on it?
Old Dec 18, 2009 | 06:47 AM
01FbTaWs6's Avatar
dude. Just keep it!!! The noises are normal,your gonna have more noises the more you mod the car.
Old Dec 18, 2009 | 07:03 AM
greasess's Avatar
I guess I'll get used to it. I'm gonna put it on the dyno to see how much i lost. I'm thinking a 9 might not have alot more loss than a loose as hell 7.6. I had 345 and 358 before. It's gonna be the same dyno but a different day so i might not get a good answer but we will see. It should be enough to beat my friend's mustang.
Old Dec 18, 2009 | 08:08 PM
Tally TransAm's Avatar
after a while youll relearn how to drive it and can pretty much make it silent if you want or noisy as hell if you want
Old Dec 27, 2009 | 01:08 PM
shedijames's Avatar
i have been thinking of getting a wavetrack too i just cant stand all the clunking and noise making. I also run a 6 speed and i prefer to keep my tranny and everthing else as healthy but maintain my performance built as well. Any suggestions where i should pick one up??
