Pic request on Thunder Racing Stud Kit
Can someone please provide a picture of the studs installed in the rear before putting the cover on? I would feel better seeing what the final result should look like when I'm done. I did a search, but never found what I was looking for.
Secondly, anyone know what size allen socket is used to torque down the studs?
Thanks in advance!
2 on each bearing cap. pull one bolt out, and put the studs in...repeat.
that's like asking for pictures of lug nuts installed....its not complicated.
i put the kit on my car, had to grind MAJOR clearance into the inner edge of the gasket surface on my diff girdle for the studs to clear.
Thanks.
Edit: a searched turned up that yours was a MAC. I bought a T/A cover, so maybe it has provisions for the studs on the cover.
