Will this work?
Old Feb 10, 2010 | 04:37 PM
UrSmked's Avatar
Default Will this work?
Will a 9 inch bolt in housing and axels for a 3rd gen camaro work on a 4th gen car?
Old Feb 10, 2010 | 05:07 PM
Zmg00camaross's Avatar
The housing is a little shorter i think 1.5 inchs on each side.
Old Feb 10, 2010 | 05:32 PM
UrSmked's Avatar
I also already have a BMR adj. torque arm. Will this bolt up to the 3rd gen rear. Also, what about the brakes will my disk brakes work or will I have to change that around too?
Old Feb 11, 2010 | 07:56 AM
BMR Tech's Avatar
Our torque arm will work no problem.....
The disk brakes I believe will not work but I'm not 100% sure.....
Old Feb 11, 2010 | 10:55 AM
ssvert99's Avatar
LS1Tech Premium Sponsor
the torque arm from the 4th gen should fit the 3rd gen rear, the 3rd gen rearend is in fact 1.5 inches shorter per side. you will need the correct offset wheels to make the rearend work in your 4th gen car. you may be able to use your 4th gen brakes but that will depend on the housing end that was installed on the rearend. post up a pic of the housing end and axle setup and we can tell you more.
