need help with "ABS INOP" light
Old Feb 13, 2010 | 01:11 PM
Blacked_Out_SS's Avatar
Default need help with "ABS INOP" light
so a while back i broke a bolt off the back side of the ring gear and broke the stock 3:42 carrier..... i have since gotten a used carrior(with less miles) and replaced it and had a suspension shop check out the ring gear to make sure it was good..... got it all put back together and the carrier works perfect but during deconstruction i pulled out the "ABS" sensors on the backing plate behind the rotors and now with it all together and working i now have a "ABS INOP" light on and my "TCS" wont turn off at all...... any ideas on what happened to them to make them go bad all of a sudden???? and where to get new ones
Old Feb 13, 2010 | 01:41 PM
ABQ99TA's Avatar
Did you un hook the battery when this was done? You might just need to pull the - cable from the battery for 5 min and put it back on to reset the computer.
Old Feb 13, 2010 | 01:50 PM
well the car has been in storage for the past year..... stored without the battery and i'm getting it going again today...so the prob could just "Go Away" is what your saying???
Old Feb 13, 2010 | 02:20 PM
Joshiedoom's Avatar
I would clean the sensors and the rings and make sure all connections are fine, with the battery cable off.
Old Feb 13, 2010 | 03:07 PM
ABQ99TA's Avatar
Could.
Old Feb 14, 2010 | 12:14 PM
hlaalu's Avatar
might be the ebcm, that's what my problem was. you can pick up a working one from ebay for around $45.
Old Feb 14, 2010 | 12:38 PM
what is EBCM???? hahaha sorry i'm not to knowledgable in the brake sensor department....
Old Feb 14, 2010 | 01:32 PM
hlaalu's Avatar
the electronic brake control module. it's that box connected to your abs block.
Old Feb 21, 2010 | 12:51 AM
ahhwataday's Avatar
Never thought of that. My ABS INOP light is on too
