Rear end replacement help.
Old Feb 18, 2010 | 07:06 PM
WizardofDetailing's Avatar
Default Rear end replacement help.
What is the difference between a 4 channel and a 3 channel. I have a 2000 Trans Am 6 speed no traction control and want to know which rearend I have and will either one work? Also, what else should I replace while I'm replacing the rearend? Any help would be great, thanks.
Old Feb 18, 2010 | 08:29 PM
penningta's Avatar
IF you dont have traction control you have a 3 channel. How much hp you making will make a big differance on what else to get,
