rear end grinding
At first i thought it was my brakes rubbing, but after taking them off and putting the car in gear, the noise is still there.
it really seems to be coming from the passenger side, and the sound was 10 times worse on jack stands than it is on the road. It also may be coming from the drivers side, but from walking around the car with the wheels spinning i would have to say pass. side is worse
the best way i can describe the noise is when you have rusty rotors and stop for the first few times, you get the grinding noise.
Its been doing this for the passed 2 years, and 20,000 miles, i never did anything about it because i thought it was the brakes.
anyways, after doing a bit of research i have found some things it might be:
1. pinion bearing - if this were true, wouldnt it sound like it is in the center of the car? I replaced the pinion seal and im sure i didnt get the pinion nut on perfectly, the noise didnt change
2. c-clips wore out the axle, i can move my pass. side axle in and out maybe 1/16" I was told there should be no play like that in them
3. axle is pitted
4. wheel bearing, i would think the problem would have gotten way worse after all of this time
anyone else have opinions?
use a mechanics stethascope, they are cheap and very useful.
your lucky, my noise is on the road only. Its quiet on the jackstands. I'm pretty sure mine is from overtightening the pinion nut, then loosening it up when I replaced pinion bearings. going to go back in and redo it all.
