Rearend Issue
Old Apr 3, 2010 | 03:22 PM
corpserodeo666's Avatar
Default Rearend Issue
I have a Moser 9" in the back of my TA and everything is fine with it. But when I drive the car it sounds like its bottoming out on the bottom of the car. It's not a major issue as the car drives fine. But I looked on the bottom of the car and I can see where it's hitting. Is there a way to fix this issue?
Old Apr 3, 2010 | 04:58 PM
SLOWWZ28's Avatar
My 12bolt made it's way into my floorboard also right at the torque arm!
Old Apr 3, 2010 | 05:39 PM
Thats exactly whats going on. Is there a fix for it?
Old Apr 3, 2010 | 05:59 PM
Sprayed 99's Avatar
it'll clearance itself eventualy or u can take a hammer and beat the metal where its hitting the tq arm
Old Apr 3, 2010 | 06:03 PM
I was thinking of doing the hammer trick. If thats an easy fix than I will def. get it cleared up tomorrow. Thanks for your advice Sprayed 99
Old Apr 3, 2010 | 06:06 PM
SLOWWZ28's Avatar
I don't think it can be completely eliminated! I ground down the top corner of the arm, and the damage was already done to the body so I painted over the gouge in the body. No more damage had been done yet! The 9inch is bigger so i'm not sure, mabey put a couple people in the back seat hit some speed bumps and let nature take it's course then paint over the damage to avoid rusting.
