What Gears
I am looking at 3.73's or 4.10's. It is a 6 speed so what kind of gas milage dose everyone get with this set up and what company makes a good gear. i.e. last as a daily driver and strip car.
With a m6, mpg won't really drop like it would in an a4, and as for a strong set of gears, nothing will be "strong" in a 10 bolt. The gears also have a bigger chance in breaking the higher ratio you go.
Most people say that the 3.73's aren't a large enough step up from the 3.42's to be noticeable. And IMO the small pinion in the 4.10's seems to make for some strength issues, esp. with the 7.5 10bolt.
I DD mine also and haven't noticed a huge difference in fuel mileage but it definetely increases the fun factor.
Bottom line it's your descision !!!
Seems like you know the pitfalls of the 10 bolt already so I won't insult you.
If you aren't putting hard launches on it and watching the wheelhop you will be fine for a while.
We have a local guy (Unstang, he is a member here) who has cut a 1.53 I believe on the 10-bolt with ET Streets.
