9" rear width
Old May 17, 2010 | 10:06 PM
1994z's Avatar
Default 9" rear width
any one have a 9" out of there car that has been narrowed 3" per side from a stock width 10 bolt, that can get a measurement for me. from center line of the pinion to the right side of the housing end. and from the left side center line of the pinion to the housing end. thanks..
Old May 19, 2010 | 05:58 PM
1994z's Avatar
wow.. no one.
Old May 19, 2010 | 09:10 PM
frog1991's Avatar
Look at the catalog on the Strange Web Site page 77
Old May 20, 2010 | 05:53 PM
1994z's Avatar
that would work if i had a 12 bolt. building a 9"
Old May 21, 2010 | 09:56 AM
jmm98LS1's Avatar
Are you just wanting measurements for axles? I have a 9" housing with 3"/side cut off and the matching axles, but don't have the third member put together yet so I can't measure from pinion centerline. I can measure my axles for ya if that helps.....
Old May 22, 2010 | 08:13 AM
1994z's Avatar
yes you can. that will work real good. from outer axle flange to the end of the splines for left and right. if you go to the moser website and look at the axle order form it shows the letters and where to measure from. thanks roger..
Old May 25, 2010 | 08:30 AM
jmm98LS1's Avatar
30.125" long side and 27.5" short side
