Quick Driveshaft Question!
Old May 19, 2010 | 10:00 PM
BAMALS1's Avatar
Default Quick Driveshaft Question!
I have an A4 with a steele driveshaft with the stock 10 bolt rear. I bought an aluminum driveshaft and want to install it.I measured the alum shaft 41 1/2" u-jint to u-joint...my steele shaft measure's 41 1/4" u-joint to u-joint. Will the aluminum shaft work? Are the yolks different in length? Thanks!
