Torque Arm or Mini 4 Link...
Old May 27, 2010 | 08:13 PM
SoxXpupPeT's Avatar
Question Torque Arm or Mini 4 Link...
Ive started the build up of my 8.8 again and i have a question. My car is daily driven and is aimed towards handling. It will very rarely see time at the strip. Which would be better for handling. Leaving the torque arm or the mini 4 link setup most people run with modified 8.8's Ive heard there isnt a noticeable difference with the mini 4 link setup as far as feel over the torque arm. is that true ?
Old May 27, 2010 | 08:15 PM
venom99's Avatar
been doing alot of reading on the 8.8 yes that is true
Old May 27, 2010 | 09:07 PM
Outlaw72's Avatar
The torque arm suspension does not need to be changed on these cars. Stiffen everything up with spherical rod ends and let er rip. Unless you are doing a full back half and looking for more than 2,000 HP, the torque arm suspension is just fine.
Old May 28, 2010 | 04:48 AM
96lt1m6's Avatar
I have the mini bar set up, its more like a ladder bar set up and it does ride a little bit rougher but it does seem to launch harder!
Old May 28, 2010 | 01:32 PM
SoxXpupPeT's Avatar
thanks for the responses guys. my cars more for handling. I just wanted to see what everyones thoughts were on the two setups. if it would handle just as good with the mini 4 link as apposed to the torque arm then id just go the 4 link route.
Old May 28, 2010 | 09:18 PM
massconfusion's Avatar
4 link is much easier to build but i built mine with a t/q arm mount
Old May 29, 2010 | 10:32 AM
SoxXpupPeT's Avatar
Thats partly why id rather just do the mini 4 link.. idk how much of a PITA itll be to do the torque arm set up and get it 100%
Old May 29, 2010 | 11:00 AM
its easier then you think but you have to tack it from undreath your car to insure good fitment. Their is a suprising amount of movement in the t/q arm so it is not as crucial as you might think. IF you really want it go for it.
Old May 29, 2010 | 11:42 AM
1BAD01TA's Avatar
well put, the panhard rod controls the side to side movement, the only difference i noticed in my car was much harder bite on the tires. Most people who ride in my car dont know unless i tell them.
Old May 30, 2010 | 07:37 PM
SoxXpupPeT's Avatar
Thanks for the feedback guys. the more i think about it the more i realize that the torque arm can be abit off and still do its job. i suppose ill be putting using it
