Time for a new Differential.
Old Jul 15, 2010 | 05:42 PM
saltwaterreefguy's Avatar
Default Time for a new Differential.
I think it maybe time for a new differential and gears....tell me what you think...
What causes this this is the only part of the rear-end that I can find with any serious damage or wear marks, why?
Old Jul 15, 2010 | 07:34 PM
do i need to replace it?
Old Jul 16, 2010 | 10:53 AM
Bump^
Old Jul 16, 2010 | 11:04 AM
ssvert99's Avatar
LS1Tech Premium Sponsor
does the car burn both tires still(posi working good or not)? that is a your side gears and they are only spinning when the car turns. the sharper the turn the faster they spin. most of the time you see something like this its not hurting much and is usually caused from the car doing one wheel burnouts. M6 cars are more likely to have this happen as well due to the on-off shock loads seen during gear shifts.
do you need to replace it? that's you're call as it really isn't doing much, but at the same time isn't just normal wear to see side gear teeth chunk like that. if the posi doesn't hold then absolutely replace it as the diff unit isn't doing its job anyway.
It's an Auburn anyway... not that good when it was new. once an Auburn posi wears there is no repair. Get into a Eaton and don't look back if you are gonna keep the 10 bolt in it.
Old Jul 16, 2010 | 11:32 AM
Thank you very much, it was making a grinding sound any speed over 30mph, on or off the gas... so I think I'm just going to save up for a new rear.
